rear end lift?
Discussion in 'Lifted & Offroad Suspension' started by k/4x4/93, Mar 24, 2010.
  1. k/4x4/93
    k/4x4/93 Member
    I have a 1993 chevy 1500 that sits level. i want the rear end lifted only so it sits with a forward angle with the rear up and the nose down. whats the best and cheapest way to do that. i thought about "add a leafs" but i dont know about that stuff.
  2. Stealth
    Blocks work too, and you can also get extended shackles that will lift the rear an inch or so.
  3. BadBurban98
    BadBurban98 Rockstar
    blocks are the easiest way to go and will maintain ride quality doing a shackle lift will stiff the ride a bit and if you put a have load there know to push out and lock up and the rear end will sag I've had it happen to me, I'd say the blocks.
  4. pmartin816
    pmartin816 Rockstar 4 Years 1000 Posts
    I think the blocks are gonna be your best bet.
  5. Stealth
    My vote against the blocks is that they can pop out and they accelerate axle wrap. If you can get around these problems blocks are excellent cheap alternatives.
  6. canislupis69
    I would recommend blocks over add a leafs as the AAL's will stiffen the ride. If you are worried about axle wrap you could always go with a zero rate leaf aal. It lifts like a block but is bolted to your leaf pack so no axle wrap. Here is a link for 1 inch zero rates, this site also sells 2.5 inch zero rates as well.
    http://www.offroaddesign.com/catalog/Zero Rates.htm
  7. k/4x4/93
    k/4x4/93 Member
    What are the best blocks to buy? can i have a couple URL's
  8. k/4x4/93
    k/4x4/93 Member
  9. BadBurban98
    tough country makes good lifts and you went to a good site too, i have a 4" tough country suspension in my 88 toyota granted it rides stiff only because i went with a high arc leaf spring so I wouldn't have to use blocks but, yes my friends has used that kit and likes it and it maintained ride quality
