Rear End Noise - Worn Tires?
Discussion in 'Chevy Suburban Forum (GMC Yukon XL)' started by Tom Evans, Jun 26, 2011.
  1. Tom Evans
    Tom Evans Rockstar 100 Posts
    I have a 2002 1500 2WD Suburban with 126,000 miles. Recently it has developed a noise in the rear end. I hesitate to say differential noise, because I am not convinced that is the souce of the noise. I checked the lubricant level and it was correct. I went ahead and changed the lubricant as recommended in the owner's manual as well as added a bottle of GM's Limited Slip Axle Lubricant Additive (PN 1052358). The noise appears to be about the same.
    What I am leaning toward are the tires. They are Dunlop AT21 tires. They have about 4/32" tread left with fairly uniform wear. The noise is definitely not a growl (bad bearings) and is not resonant between 40-50 (bad ring gear and pinion).
    Are there any tests I can do to determine if the tires are at fault, other than try another set?
    Thanks.
  2. stephan
    Does the noise change any between on the gas & off, or does it change any depending on pavement surface like cheater pavement?
  3. Tom Evans
    Best I can tell there is no (or little) difference between gas on (drive) and gas off (coast). No difference between types of pavement. I had a liberal education about a worn ring gear and pinion with a old Mercedes I once owned. I could rebuild that differential in my sleep before I sold the car. Other that that, I wished I still owned that car.
  4. stprovost
    stprovost New Member
    I have a 2003 chevy burb and had to replace the rear end last year due to evidence of heat in the diff housing.
    I also had a rear noise and use 16 inch tires.
    Not a big fan of this vehicle either, to date the whole power train has been replaced due to cheap materials!
    stephen
  5. Tom Evans
    Stephen,
    What were the symptoms of your differential trouble? I noticed when I replaced the differential lubricant that there were no particles (metal or clutch material)in the oil and it smelled OK (as good as differential lube can smell). Did you have noise, jerkiness, etc.?
