rear side window
Discussion in 'General Chevy & GM Tech Questions' started by gunit, Apr 27, 2010.
  1. gunit
    gunit New Member
    I have a 2002 1500HD the passanger rear side window won't go up or down, I checked the switch it is fine. I'm not getting any power to the switch and can't figure out on the master switch which wire controls that window. Is there any fuses that I'm missing? the other three windows work fine!!
  2. mudskipper
    mudskipper New Member
    should be 1 fuse and 1 relay. check your wiring harnes going from the piller to the door for breaks
  3. gunit
    gunit New Member
    where do I find that fuse and reley? under hood?
  4. Loggerhead Mike
    relays are internal in the switch
    check the fuse in the i/p panel if good swap the circuit breaker
    wich wires for the switch did you test?
  5. Viper
    Viper Rockstar 100 Posts
    if the other 3 windows work correctly, its is a wiring fault with the rear pass, if someone has access to the wiring for that power window circuit, then you could trace your wires, if activating the switch on the driver master panel does not work then that would be a good place to start, also, check the jams of the doors as it may be pinched or cut all together.
