Recommended bolts to attach engine to stand
Discussion in 'GM Powertrain' started by Breadfan, Aug 10, 2009.
  1. Breadfan
    Breadfan New Member
    Hi folks,
    Hope this isn't too odd or easy a question :)
    I'm planning on pulling the engine and trans from my 1995 Suburban this coming weekend. The trans is bad due to a case cracked in half, so I figured I might as well just pull the whole thing and take the opportunity to go over the 170k 350, change some seals, etc.
    I have an engine stand, and would like to attach the motor to it once seperated form the trans.
    Question is - what bolts should I use? I don't think the bellhousing bolts would fit through the attachment "arms" which appear to be a good 2-3" tubes. Also I've heard it's recommended to use other bolts anyway, incase anything bends you don't ruin a bellhousing bolt.
    So, has anyone done this on a 350 and what size bolts and or nuts doe you reommend I pickup prior to starting this job?
    Thanks!!!
  2. Crawdaddy
    Use bolts with the same threading, but of an appropriate length to go through the stand and get a full bite in the block. I would say use Grade 8 bolts, but if I do something involving bolts, I always use Grade 8 if it's available. I'd imagine Grade 5 would probably hold the motor up, but don't quote me on that. I think a fully built out 350 (block, heads, internals, and maybe even accessory mounts would weigh in the range of 500-600 pounds, so it's always better to go overkill than possibly lose a foot or other appendage to a falling motor.
  3. Breadfan
    Breadfan New Member
    Thanks! I'm going for Grade 8's to be safe.
    Do you happen to know the thread pitch and bolt site (diameter) of the bellhousing bolts?
    I'll spend some time toinght searching/googling at anyrate. Thanks!
  4. Z71_guy
    when you get the bolts off take one in to the store and have them match it up with the longer one you need
  5. Breadfan
    Breadfan New Member
  6. Breadfan
    Breadfan New Member
    Well last night I got under the truck and pulled one of the bellhousing bolts. (Not one of the converter inspection plate bolts, an actual bellhousing bolt). I think what I found online may be right - 3/8 x 16 thread pitch. But at anyrate I have it and will take it to the hardware store.
    It looks like on my engine stand I'll need bolts 3.5 inches long.
    We'll see what I can find in Grade 8
    Sweet!
  7. Jimmiee
    Don't sweat it if you can't find grade 8. Grade 5 will suffice. A grade 5 bolt is plenty strong enough.
  8. olblue91
    olblue91 New Member
    i just put my 350 on a stand a couple days ago. i used 3/8 coarse thread, about 2" long. they are grade five, and i used four. it is holding up very well.
    one thing to remember about grade 5 vs grade 8. grade 5, although weaker, will tend to bend on loads that are too heavy. a grade 8 bolt will tend to break in two pieces, once it reaches its max load. like i said....i used grade five, and it's holding up nicely.
  9. azdrtdog
    azdrtdog Epic Member 5+ Years 100 Posts
    grade five are the recomended bolt for excatly that reason just make sure you get in at least 3/4 inch for a 3/8 to hold
  10. Jimmiee
    I've been using grade 5 bolts for years. After all if the factory uses them to hold the transmission to the engine I would hope they would hold the engine to an engine stand. :)
