Recommended tires for plowing???
Discussion in 'Wheels & Tires' started by 95RedBarn, Nov 17, 2010.
  1. 95RedBarn
    95RedBarn New Member
    Im looking for ppls opinions on what a good tire is to run on my plow truck...95 sierra 4x4 1500. This is my first year plowing and I never run snow tires as I just run what I have. Im not looking to spend much money either seeing as Im pretty much flat broke right now unfortunatly. I live in Eastern Ontario and see a pretty decent amount of snow where I am.
    Thanks
  2. MPC-Silverado
    MPC-Silverado Rockstar 3 Years 100 Posts
    i ran stock 2500 tires most of last winter. they were ok... almost a little to small for what i was doing tho... i got 33" tires for this year to put on in the winter... they should work alot better... if you dont want to blow any money try running what you got and after you made some cash then maybe upgrade
  3. 95RedBarn
    What I have right now are definatly NO GOOD for snowy conditions...nearly slicks, also a reason Im looking for opinions
  4. ridick_bowen
    ridick_bowen Rockstar 100 Posts
    Toyo A/T's!!!!!!!!!!!!!!!!
  5. randomsandwhich
    randomsandwhich Rockstar 3 Years 100 Posts
    any a/t tire should work well, unless you have money and can afford snow tires.
    I have nitto a/t not sure of its snow ability yet, won't know until it snows. My old stock tires which were goodyear wranglers at/s.. horrible in the snow.
    maybe cheap tires and run chains? if your local/state laws allow them.
    Any tire with deep grooves should work pretty good !
  6. 2COR517
    Tall and skinny tires are great in the snow. Putting some 235/85 on the 96 Tahoe. Probably going to go with Michelin LTX so I can run them year round. But they are expensive. On a budget, look at MasterCraft MSRs. Or TreadWright retreads with Kedge Grip.
  7. MPC-Silverado
    i disagree tall and skinny tires work good in snow but not for plowing... the power need to push and the snow and the straction needed to put the power down just isnt there with thin tires. i hated my stock 2500 tires
  8. 2COR517
    I don't whether to laugh or cry at that statement. How can a 235/85 Load Range E be rated for 3,042 lbs and be very popular in the one ton/towing crowd?
    How much plowing have you done?
  9. randomsandwhich
    Well tall and skinny would give you a less of a footprint -- however, this would put more pressure on the snow, and therefore provide more traction. A wider tire would have a bigger footprint but it would act like a snowshoe and sit on top of the snow with less downward pressure.
  10. mfleetwood
    I like your snowshoe analogy....definitely helps me understand the answers better.
