Recon Projector Headlight Adjustment?
Discussion in 'Chevy Truck Accessories' started by RagsCo4, Jan 1, 2012.
  1. RagsCo4
    RagsCo4 New Member
    I just got a set of Recon projector headlights for 07 Silverado. The beams are way off on them and I need to adjust them, I am not sure how to do this. If anyone can help me out that would be greatly appreciated!
  2. CustomTruckParts
    CustomTruckParts New Member
    Here are the steps on how to adjust your Recon Headlights.
    1. Make sure there is little light (make the adjustments at night)
    2. Vehicle should be on a flat surface against a flat wall
    3. Park vehicle 30 feet from the wall and turn your lights on
    4. On the back of your Recon Lights, there should be 4 adjustment screws
    5. Adjust them until the beams are 2” below center of the wall
    Hope this was helpful. Good luck!
  3. RagsCo4
    RagsCo4 New Member
    Thanks for the info. I finally got them adjusted, unfortunately to do that I had to remove the passenger side headlight to access the adjustment. There is no way to get at it with out taking the light out. As far as the adjustment goes, there is only an up and down adjustment for the Low Beam, while the High beam has 2. Thanks for your help!
