remote starter
Discussion in 'Audio, Video & Gadget Tech' started by chevymason, Nov 16, 2010.
  1. stinger44
    stinger44 Rockstar
    Agreed. Thanks.
  2. 99'HEARTBEAT
    To add the....Factory Remote Start.....Look and See if you have RPO Code "AP8" on the Service Parts I.D. Tag (White Sticker) Inside Your Glove Box.......If you do see RPO Code"AP8".......then you have the Factory Remote Starter Prep-Package.
    You then Would buy from either G.M. Accessory Web Site or your Local G.M./Chevy Dealer.......the Factory Remote Starter System, The Kit Includes Two Remote Fobs and an Unlock
    Authorization
    Security Code that the Dealer Needs when they call G.M.......THIS SYSTEM MUST BE PROGRAMMED BY YOUR Local G.M./Chevy Dealer.....Once the programing is done....you would have the Factory Remote Start.
    The Factory Remote Start Fob
    [​IMG]
    Remote Start:
    Upgrade your factory remote key-less entry to a standard Remote Start system, or choose the advanced technology of the 2-Way Advanced Remote Start featuring extended range and enhanced functionality. Both are seamlessly integrated with your Silverado's anti-theft and remote key-less entry systems.
    Factory Remote Start - For Use on Vehicles with Extended Range Remote Lock Control (AP8), Includes 2 Fobs
    17801236
    $ 195.00 ​
    Below is from G.M. Accessories Web Site it is a list of the other Factory Remote Start's.......also showing what RPO Code is needed for that Corresponding Factory Remote Start,
    Accessory Name Part Number
    MSRP (USD) ​
    Select the accessories that fit your style:
    2-Way Advanced Remote Start - For Use on Vehicles with Extended Range Remote Lock Control (AP8), and Models without Rear Defog (C49) and 5-Speed Manual Transmission (TZ0)
    19213166
    $ 250.00 ​
    2-Way Advanced Remote Start - For Use on Vehicles With Remote Keyless Entry and Engine Start (AP3), But Without Rear Window Defog (C49)
    19213167
    $ 150.00 ​
    2-Way Advanced Remote Start - Use on Extended Cab Models with Remote Keyless Entry and Engine Start (AP3) or Crew Cab Models with Remote Keyless Entry and Engine Start (AP3), But Without Rear Sliding Power Window (A48)
    19171129
    $ 150.00 ​
    2-Way Advanced Remote Start - Use on Non-Hybrid Vehicles with Keyless Entry (AU0), But Without 4.3L Engine (LU3), 5-Speed Man. Trans. (TZ0) and Rear Window Defog (C49)
    19213165
    $ 295.00 ​
    2-Way Advanced Remote Start - Use on Regular Cab Models with Extended Range Remote Lock Control (AP8), But Without 5-Speed Man. Trans. (TZ0) and Rear Window Defog (C49), Crew and Extended Cab Models with Extended Range Remote Lock Control (AP8), But Without 5-Speed Man. Trans. (TZ0) and Rear Sliding Power Window (C49)
    19171128
    $ 250.00 ​
    2-Way Advanced Remote Start - Use on Regular Cab Models with Keyless Entry (AU0), But Without 4.3L Engine (LU3), 5-Speed Man. Trans. (TZ0) and Rear Window Defog (C49), Crew and Extended Cab Non-Hybrid Models with Keyless Entry (AUO), But Without 4.3L Engine (LU3), 5-Speed Man. Trans. (TZ0) and Rear Sliding Power Window (A48)
    17802087
    $ 295.00 ​
    ** MSRP. Excluding installation, taxes and wheel components (if applicable). Dealer prices may vary. Some accessories may require purchase of additional equipment and/or services. See your dealer for details.
    Edit: The above information is for......The Factory Remote Start....for the.....2007" To 2013" GMT-900 Series NNBS Trucks/SUV's......There is No Factory Remote Start for the 1999" to 07" GMT-800 NBS Trucks.
    Edit.....The Pricing Above, Is from Nov. 2010".....So the Cost of the Factory Remote Starter System, has Most Likely Gone up, over this period of Time.
  3. mfleetwood
    Great info as always Mike!!! It's like you wrote the book on so many items!
  4. stinger44
    stinger44 Rockstar
    Are you talking the "service parts list" sticker in the glove compartment? If so, I didn't see the AP8 code as one of the listed codes.
  5. mfleetwood
    It is a small sticker (about 3" x 4") with a ton of 3 digit codes. Mine is on the side of the glove box closet to the passenger door. Or, you can enter you vin though the link below and it should comeback with your RPO codes as well.
    http://www.compnine.com/vid.php?vin
  6. stinger44
    stinger44 Rockstar
    Unfortunately, that AP8 code is not one listed. Ive got a call into my local Chevy dealer to confirm it's not compatible. Thanks.
  7. 99'HEARTBEAT
    Yes.....the RPO Code's on the......SPID Label in the Glovebox.
  8. stinger44
    stinger44 Rockstar
    Just confirmed my vehicle doesn't have the pre-package. Was a nice thought though, thanks.
  9. randomsandwhich
    randomsandwhich Rockstar 3 Years 100 Posts
    does anyone have those advanced 2 way remotes? is it worth to go with the basic factory remote start for 195.00 or spend the extra 55 for the 2 way. My trucks has the dl8 code, i'm interested in doing this. Has anyone followed through and did the dealership charge for programming?
  10. 99'HEARTBEAT
    Did you mean to type....RPO Code AP8.....instead of....dl8...??
