    Join Today ~ It's Free
Remote turn on for amp
Discussion in 'Audio, Video & Gadget Tech' started by kgibson181, Mar 14, 2010.
  1. kgibson181
    kgibson181 New Member 1000 Posts
    Hey guys, what could I tap into for my amp's remote turn on wire? Also when I do tap into something, what size fuse would you recommend to fuse it with, because i know I need to fuse it to be safe but there is tiny amounts of power going through the remote wire so it looks as if I would need to use a tiny fuse.
    Thanks any help is appreciated.
  2. ajfdirtrider
    ajfdirtrider New Member
    Did the same with my amp. Just go to your local auto parts stores and pick up a three prong swith (+ in, ground, + out). Wire it up to your remote wire on your amp, mount it, and your good to go. Did this to my amp a year and a half ago and havent had any problems.
  3. ZSI52
    ZSI52 New Member
    Are you just adding a amp to the factory setup? Or did you replace the deck to?
  4. kgibson181
    where did you run the positive in from?
  5. kgibson181
    and ZSI52 this is all still with the stock head unit
  6. lancer
    lancer New Member ROTM Winner
    if your useing a factory deck i'd run a wire from the fuse box to a switch to use as the on off switch. just put a fuse inline and you should be fine.
  7. kgibson181
    that sounds good. what amperage for the inline fuse would you recommend?
  8. lancer
    i'd go 5-10 i just rand my cd player to my fuse box and i put a 10 amp fuse in it.
  9. kgibson181
    ok hopefully that'l all work out. I'm ready to get my subs goin!
    Thanks for all the help
  10. Stealth
    Stealth New Member 1000 Posts
    This is what I did with my system, and I've had zero problems yet. Let us know how it turns out.
