Removal of ABS on a 94 Suburban
Discussion in 'Chevy Suburban Forum (GMC Yukon XL)' started by Marc L, Jul 23, 2012.
  1. Marc L
    Marc L New Member
    I am wanting to get rid of the ABS in my 94 1500.Has anyone done this ? Any help would be great.Thanks
  2. moogvo
    Pull the fuse. The brakes will not operate any differently other than any other vehicle without ABS.
  3. Marc L
    Marc L New Member
    Thanks. I was thinking getting rid of that small anchor on the drivers side inner fender.Can I use the same master cylinder ?
  4. moogvo
    That I don't know. I don't know that I would be in a hurry to remove the module. You might run into complications. I would guess that you probably will have to replace the master cylinder as well.
  5. TimTom64b
    2nd the full the fuze
  6. RayVoy
    I had a '96 and pulling the fuse solved the problems I had. Leave the module, removing it is not worth the work, or the time.
  7. Marc L
    Marc L New Member
    So I will be pulling the fuse for now..Thanks
