removing catalytic converter
Discussion in 'GM Powertrain' started by boatman2089, Dec 8, 2009.
  1. boatman2089
    boatman2089 New Member
    on my 02 silverado with the 4.3L the drivers side converter is vibrating so bad that its drowning out the sound from the radio and you can feel it throughout the truck, the truck has 173,000 miles on it and i really don't feel like spending the $$ on replacing the whole thing, and the truck has tripped the code for the converter (i don't know the code off the top of my head). my question is can i just cut the one converter off and put a piece of pipe there without removing the other? will the truck run funny if i just remove the one side without doing the other side?
    anyone run into this problem or have and input on this? advise on this is hugely helpful, thanks
  2. silveradotrailblazer
    You can buy replacement converters for your truck for under $100.00 each. With over 173,000 miles on the truck I would replace both. You truck will run better.
  3. vncj96
    you can get universal magnaflow cats for 83 a piece on ebay, sometimes even less. Its cheaper then the fine you would get if you would get caught without them on the truck
  4. Crawdaddy
    There is little reason to not run a catalytic converter on your vehicle. Like everyone else has said, high-flow cats can be had for very cheap, and the motor may very wellrun WORSE without them because the computer is looking for feedback from the sensors to indicate that the cats are doing their job.
  5. boatman2089
    ok thanks to the both of you, ive found those flowmasters that you were talking about for cheap and ill have my exhaust guy install em:great:
