removing fender flairs
Discussion in 'Chevy Truck Accessories' started by truckguy, Dec 20, 2008.
  1. truckguy
    truckguy New Member
    I have a 2006 chevrolet Silverado crew cab.
    I got the truck from auto trader seller. It has fender flairs on it and I want to remove them.
    Two questions : How do I remove them if possible and what tools will be needed? difficulty scale 1-10 ten being to much for a do it your selfer.
    If they can be removed will the truck look like other trucks from factory that didnot have the flairs?
    Any and all replies will be appreciated very much.
  2. ct9a
    Never put any on, so I can't help you there, but I would think that if they aren't drilled on, there will be some paint differences. Think cars that have had bras on the front.
  3. tlperry68
    Someone did this a couple of weeks back. Do a search for it and it will pop up. Also it is addressed in this months issue of 8 lug magazine. It looks like it was pretty easy to do.
  4. Foglio1121
    Foglio1121 New Member
    i havent done it, but i imagine that if it is glued, u will have paint peel, and if it is drilled ud have the holes. also u would have a color difference, because of the wear and tear and the sun being on the rest of the truck
  5. truckguy
    truckguy New Member
    removing fender flares
    Hey guys thanks for the replies. hopefully someone has removed theirs and they will let me know what all they had to do.
  6. walleye101
    walleye101 Member
    i installed them before. you can remove them quite easily, all you have to do is remove the 7 push pins on the inside of the fender and they should come off pretty easy. they also have 3m 1/4 2 sided tape that helps hold them on to the outside of the fender. are your flares oem? and are they smooth or testured flares? do you want to sell them? let me know. thanks
  7. JMoney02
    You are most welcome.........
  8. truckguy
    truckguy New Member
    Hey Walleye101,
    thanks for the help. I am new to this site so can you tell me how to get to the photo album of your truck. After I get these things off I will post a reply and hopefully try to get some pictures of the flares and let you see them and make me an offer.
  9. walleye101
    walleye101 Member
    you click on my name then, you click on my public profile and in the right hand corner toy will see my album. click on it and go through the pics. Darryl
  10. truckguy
    truckguy New Member
    removing fender flares.
    I saw your pictures of the white suburban? and it had the flares? Looking at it, it no way one could know there were flares on it. After seeing that I am going to remove mine this weekend when the weather is a bit warmer. Thanks for the help from you and Walleye.
