removing interior doors panels
Discussion in 'Chevy Silverado Forum (GMC Sierra)' started by orange f7 snopro, Mar 3, 2010.
  1. orange f7 snopro
    orange f7 snopro New Member
    just wondering how to remove the interior door panels on my 09 silverado? i have removed the interior door panels on my previous trucks. the interior door panels on my 09 are different from on my 07 classic and my 05 that i had.
  2. Greg84
    Greg84 Rockstar 100 Posts
    There are two bolts under the pull handle you use to close the door, you have to pry up the trim piece first (there's a little slot at the bottom to stick a screwdriver or tool like that). Take out a bolt at the top and bottom and the entire handle comes off.
    Under the door opening lever there's another plastic panel to pry off. Two more bolts under that.
    Take a really small screwdriver and with the door unlocked, pry out on the little 1/4"x1/4" square on the front of the lock button. When the little square pops out you can take the whole lock button off.
    The rest of the panel is held on with spring clips, start prying at a corner and work your hands down both sides and around the bottom, then you can lift the panel up about an inch and off.
  3. mmorgan1865
    mmorgan1865 Rockstar 4 Years 1000 Posts
    On a new truck like that it helps to do it in a warm area. I ran my heater for a while before I pulled off the panel to change the door handles. It keeps the clips from breaking.
  4. orange f7 snopro
    thanks for the help guys. i want to tint my windows and its easier with the door panels removed
  5. daweinah
    daweinah Rockstar 100 Posts
    Huh, never heard that before. Makes sense, I suppose.
