Removing Rear bumper for NNBS
Discussion in 'Chevy Silverado Forum (GMC Sierra)' started by dadngt, Jun 29, 2012.
  1. dadngt
    dadngt Rockstar 100 Posts
    I tried a site search but didn't find anything for the nnbs Sorry if I over looked it. I'm wanting to remove my rear bumper, I've seen a video on youtube but the guy took his apart into several pieces. Can I just pull it off in one piece by removing the 2 or 4 bolts to the frame? I'm planing on painting the chrome, & on my passanger side in the chrome piece is a nice dent I'm going to see if I can remove. The bumper may be off for a few days so I'll have to rig up the tag & tag light to pass mustard til I get everything back together, guess if I mess up the bumper pounding out a dent it would be all the more reason to get a roll pan lol.
    Anyway to sum it up needing tips on removing the read bumper for a 07+ Silverado
  2. 99'HEARTBEAT
    I don't know if this Diagram will help, with removing the Rear Bumper, I thought I would posted it up, just in case its able to help you??
    [​IMG]
    [TABLE="class: part_list"]
    [TR]
    [TD][/TD]
    [TD]Part No.[/TD]
    [TD]Description[/TD]
    [TD][/TD]
    [TD][/TD]
    [/TR]
    [TR="class: grayline"]
    [TD="class: td1"]2[/TD]
    [TD="class: td2"]**25542[/TD]
    [TD="class: td3"]BULB RR LIC PLT LP,LAMP #192,(ALL MODELS ALL YEARS),(12V 5W),(#168,3 CP),(08.991)[/TD]
    [TD="class: td4"][/TD]
    [TD="class: td5"][/TD]
    [TD="class: td8_2"][/TD]
    [TD="class: td10"]*[/TD]
    [TD="class: td11"][/TD]
    [/TR]
    [TR]
    [TD="class: td1"]3[/TD]
    [TD="class: td2"]**284310[/TD]
    [TD="class: td3"]PAD RR BPR STEP CTR[/TD]
    [TD="class: td9"][/TD]
    [/TR]
    [TD="class: td1"]5[/TD]
    [TD="class: td2"]**284313[/TD]
    [TD="class: td3"]PAD RR BPR STEP OTR[/TD]
    [TD="class: td7"][/TD]
    [/TR]
    [TR]
    [TD="class: td2"]**284314[/TD]
    [TD="class: td6"][/TD]
    [/TR]
    [TD="class: td1"]7[/TD]
    [TD="class: td2"]**284307[/TD]
    [TD="class: td3"]CAP RR BPR IMP BAR END[/TD]
    [/TR]
    [TR]
    [TD="class: td2"]**284308[/TD]
    [/TR]
    [TD="class: td1"]9[/TD]
    [TD="class: td2"]**519976[/TD]
    [TD="class: td3"]BOLT RR BPR IMP BAR,HFLGE,M8X1.25X20,15.6 THD,18 O.D.,8.8,GMW3359,(M8 X 1.25 X 20)[/TD]
    [/TR]
    [TR]
    [TD="class: td1"]10[/TD]
    [TD="class: td2"]**932302[/TD]
    [TD="class: td3"]RECEPTACLE TOW VEH ELEC,(INCLS CAP)[/TD]
    [TD="class: td4"] (Z82)[/TD]
    [/TR]
    [TD="class: td1"]12[/TD]
    [TD="class: td2"][/TD]
    [TD="class: td3"]HARNESS CHAS WRG,(SEE GROUP 02.000 "WIRING HARNESS/CHASSIS" FOR DETAILED ILLUSTRATED VIEW) (NOT AVAILABLE)[/TD]
    [/TR]
    [TR]
    [TD="class: td1"]13[/TD]
    [TD="class: td2"]**289435[/TD]
    [TD="class: td3"]BAR TRLR HITCH DRAW
    Replaced by: **899966[/TD]
    [/TR]
    [TD="class: td1"]14[/TD]
    [TD="class: td2"]**37772[/TD]
    [TD="class: td3"]NUT RR BPR IMP BAR BR,M12X1.75,10.6THK,28 O.D.,10,7111M,(M12X1.75),(08.917)[/TD]
    [/TR]
    [TR]
    [TD="class: td1"]15[/TD]
    [TD="class: td3"]NUT-HEX W/CON WA RR BPR IMP BAR,M12X1.75,10.6 THK,28.0 OD,10,7111M,PREV TORQ,(ALL MODELS ALL YEARS),(M12X1.75)[/TD]
    [/TR]
    [TD="class: td1"]16[/TD]
    [TD="class: td2"]**284317[/TD]
    [TD="class: td3"]BRACE RR BPR IMP BAR,(TRIANGULAR)
    Replaced by: **899963[/TD]
    [/TR]
    [TR]
    [TD="class: td2"]**284318[/TD]
    Replaced by: **899964[/TD]
    [/TR]
    [TD="class: td1"]17[/TD]
    [TD="class: td2"]**775522[/TD]
    [TD="class: td3"]BRACE RR BPR IMP BAR,(TUBULAR)[/TD]
    [/TR]
    [TR]
    [TD="class: td2"]**775521[/TD]
    [/TR]
    [TD="class: td1"]18[/TD]
    [TD="class: td2"]**508277[/TD]
    [TD="class: td3"]NUT RR BPR IMP BAR BR,HEX W/CON WA M6X1 THD,OD-19 PEOR 9,(ALL MODELS ALL YEARS),(M6X1X5.5)[/TD]
    [/TR]
    [TR]
    [TD="class: td1"]20[/TD]
    [TD="class: td2"]**609856[/TD]
    [TD="class: td3"]PLATE RR BPR IMP BAR BRKT ANC[/TD]
    [/TR]
    [TD="class: td1"]21[/TD]
    [TD="class: td2"]**516600[/TD]
    [TD="class: td3"]BOLT RR BPR IMP BAR,(M10X1.5X40,23.25)[/TD]
    [/TR]
    [TR]
    [TD="class: td1"]23[/TD]
    [TD="class: td2"]**769308[/TD]
    [TD="class: td3"]RETAINER SPA WHL LK CYL CASE[/TD]
    [/TR]
    [TD="class: td1"]24[/TD]
    [TD="class: td2"]**040331[/TD]
    [TD="class: td3"]RETAINER SPA WHL LK CYL CASE RET,(41.0 DIA X 7.1 MM)[/TD]
    [/TR]
    [TR]
    [TD="class: td1"]25[/TD]
    [TD="class: td2"]**951951[/TD]
    [TD="class: td3"]BAR RR BPR IMP (NOT AVAILABLE)[/TD]
    [/TR]
    [TD="class: td1"]28[/TD]
    [TD="class: td2"]**23101[/TD]
    [TD="class: td3"]SCREW RR LIC PLT,TAP,M6.3X1.81X16,14.55 O.D.,7114M,PZ0R[/TD]
    [/TR]
    [/TABLE]
  3. j cat
    to remove the bumper by removal of just the frame bolts you must un bolt the 8 bed bolts. then jack up the rear of the bed 2-3 inches then the bumper slides out.
    doing this and lubing those 8 bed bolts will then aid you when the fuel pump needs replacing.
    getting at all those bumper studs is a hard time consuming job . lifting the bed is quick , make sure you use some penitrating oil on those studs of the bed/bumper and work then out/in so that you do not break anything.
    make sure the 4 electrical connectors and wires at the rear are disconnected and moved to not get damaged.
