Replaced driver side mirror, compass not working
Discussion in 'GM Electrical Tech' started by NeilE, Sep 25, 2013.
  1. NeilE
    NeilE New Member
    image.jpg My 03 Suburban is equipped with auto-dimming and heated side mirrors with built in turn signals. I purchased a replacement mirror glass that is heated with turn signal, but is not auto-dimming. I installed the replacement mirror and now the compass and temp display in the rear view mirror (also auto-dimming) don't work. The replacement mirror had only 2 wires to power the heated mirror, but included an adapter cable to be used on trucks that have the auto dimming feature. Trouble is, only 2 of the 4 sockets in the plug from the truck connect to anything. If I jump the other 2 wires in the connector, will I get the compass etc working or will I make matters worse?
    In the attached photo, the plug is visible from the damaged mirror I removed. You can see 4 pins in the plug. The replacement mirror has the same plug, but only 2 pins.
