Replacing Coolant 06 Sierra 5.3L Engine Block Drain Plug?
Discussion in 'Chevy Silverado Forum (GMC Sierra)' started by weekend wrench, Dec 11, 2011.
  1. weekend wrench
    weekend wrench New Member
    I plan to drain/replace my coolant soon. I do not want to do a coolant "flush".
    My question is where, specifically, are the "engine block drain plugs"? Does anyone have good photos? I have the Haynes and the photo (p. 1-24) is so tight and doesn't provide an adequate description of location (for me). I need, at least, a reference to the locations of these two plugs (e.g., front side of oil filter...or something like that).
    Thank you for any help on this.
    Weekend Wrench
    Elgin, Illinois
  2. dipstick
    Will have two plugs at /around oil filter ..will be the bigger one. Takes a 17mm hex head. Now the passenger side is smaller above the starter.
  3. weekend wrench
    Thanks Mr. Dipstick. I found similar info on other sites after a bit of googling. Most people recommend a flush (with the t connector). I haven't done a flush or drain (in my brief tenure), but since I already bought the 50/50 Dexcool, I am going to attempt the drain this weekend. I plan to only drain the driver's side block plug as the passenger side is apparrently blocked by the starter. Interestingly, my radiator drain hose is missing. I plan to use full goggles for this job. Any further hints/things to watch out for appreciated very much.Weekend Wrench06 Sierra 4wd 5.3L 4 door 135,000 miles
