Replacing Wheel Bearing Sensor.
Discussion in 'Lifted & Offroad Suspension' started by stavropulos, Dec 10, 2009.
  1. stavropulos
    stavropulos New Member
    I have a 2001 Chevy Silverado 2500 4x4. My ABS is kicking on everytime I stop. When traveling fast I can stop on a dime, but when going slow, turning into a parking spot it wants to kick in and not stop at all. Is it the ABS sensor or wheel bearing sensor? or are they the same thing? I talked to a guy who said to replace it you have to buy the whole wheel hub. I called the dealer and they said I can just buy the sensor seperate?? If anyone has been through this I would much appreciate any assistance or input. Thank you all for your time.
  2. Rocketron
    Rocketron New Member
    If it's a 2001 chances are the bearings are shot and not just the sensors acting up as they do wear out. The entire hub assembly is not that expensive and if you have minimal tools it might be helpful to find a set with the lugs already pressed in. Two years ago I learned how to do mine after I was given a crazy quote from the stealer - I mean dealer.
  3. Jacqson
    Jacqson Rockstar 100 Posts
    If your truck is an 8 lug then you need Timken Part #SP580310. These are a complete unit with the ABS sensor and wheel studs included. They're basically a plug and play unit and just so you know Timken is the Wheel Hub supplier to GM.
  4. stavropulos
    Much appreciated ...thanks to you both
  5. BillNH
    BillNH New Member
    I had a recall for the same issue on my 01 1500. Might be worth checking into
  6. DoubleDD
    DoubleDD New Member
    My 99 does the exact same thing! Any help with suggestions? Wheel bearing or sensor? Won't show up on computer when mechanic rides with.
  7. DoubleDD
    DoubleDD New Member
    Bought 2 new front bearings from Bearing Warehouse online for $200 shipped to my door. Replaced them and the problem was gone.
