Reprogramming Necessary After Changes?
Discussion in 'Performance & Fuel' started by F E Knucklebuster, Aug 17, 2009.
  1. Still need a little help understanding the control the pcm has over changes made to improve performance.
    2004HD 6.0. Simple upgrades to improve performance. I've added a K&N CAI system, true dual Flowmaster 50s, replaced plugs (AC platinum), and replaced the plug wires (Bosch).
    Is it necessary for a pcm reprogram to take full advantage of the changes or does the pcm recognize the changes and make the appropriate moves on the fly?
  2. Jimmiee
    It is not necessary to reprogram the PCM as it is capable of adaptive learning and it will try to adapt. For instance if the idle is higher because of new air filter the PCM will lower it. The PCM can make slight changes to make the engine perform as programmed.
    Now if you want more performance then you need a performance reprogram or custom tune as it's called. This is an aftermarket upgrade and not something the dealer does. Does this answer your question?
  3. masterfoxscout
    Couldn't have said it better. Big Thumbs up!
  4. Adaptive Learning.
    Perfectly said and understood. That's what I needed to know. Thanks
  5. 2ToNe04
    A custom tune from our vendors, can help you take more advantage of this.
    I would recommend getting more upgrades..... maybe like some long tube headers, if you dont have to smog in your state.
