reverse light circuit
Discussion in 'GM Electrical Tech' started by agerangere5, Apr 11, 2010.
  1. agerangere5
    agerangere5 Member
    hey all. i have a 2009 crew cab ls 1500 and was wanting to put some lights on the hitch along with a back up camera. mu question is do you think i would be putting to much of a load on the reverse circuit if i tap into the reverse lights to get power for the camera and 2 55w driving lights. or should i just put the lights on there own circuit. thanks for the help in advance!
  2. MrShorty
    When I wired my backup camera in, I found that my trailer wiring pigtail had a reverse light circuit built into it. Since none of my trailers have back up lights, I just wired into that.
  3. anven
    anven Member
    I would check what the rating on the fuse is for backup trailer lights. I agree with previous post - backup camera getting power from the trailer harness is the best way to go. 110W worth of lights I am not sure about... 10 Amp... So if its on a 15 or more amp fuse, you should be OK...
  4. agerangere5
    agerangere5 Member
    thanks guys. i decided to just wire the lights to their own switch. this way i can turn them on when i want to. thanks for the advice though
  5. 2COR517
    Best way to do it. The NBSU switch is really only designed for the stock bulbs. If you want extra lights to come on when you go to reverse, use a relay and the hot lead in the trailer harness.
