rough idle with a/c
Discussion in 'General Chevy & GM Tech Questions' started by willardearl76, Apr 5, 2010.
  1. willardearl76
    willardearl76 New Member
    When I have the A/C on the engine has a rough idle. Also, when any fan setting is on, the A/C compressor cycles on and off.
    Is this normal?
    Is there anyway to determine if a compressor is on it's last legs?
  2. wis bang
    wis bang Rockstar 100 Posts
    If the compressor cycles it is low on freon...
  3. Chris Miller
    Also, the pressure could be too high. If there's a clog somewhere in the lines, the pressure will go up rapidly, and the pressure cut-out switch on the condenser will cut power to keep from hurting the compressor.
