rough idle
Discussion in 'General Chevy & GM Tech Questions' started by RLawns, Jan 27, 2009.
  1. RLawns
    RLawns New Member
    i have a 93 z71 with a 350. I was driving one day and it has a really rough idle and almost stalls. so i changed the spark plugs and noticed the driver side was running rich and the passanger side was running lean. What would cause this? I also changed the plug wire,cap and rotor but did not help. any suggestions??
  2. cascott325
    fuel pressure, misfire, timing?
  3. RLawns
    RLawns New Member
    its is misfiring. I havent checked the fuel pressure yet. it stops misfiring when i am going 70 mph.
  4. jlsparky7
    jlsparky7 Rockstar
    Exhaust leak causing the comp to dump more fuel?
  5. k.daddy1
    k.daddy1 Rockstar 100 Posts
    When you say the left side is running lean, does it have a crust build up on the electrode? These trucks have a history with the intake gaskets, especially on the left side. Have you had to add coolant recently? If so, instead of a fuel related problem, you may have an intake gasket leaking fouling the plugs. Just a hint, I've replaced dozens of those gaskets for the same reason, rough idle, miss, etc.
  6. mrfixdit
    mrfixdit Rockstar 100 Posts
    I agree with k.daddy1, have you had any check engine soon codes, specifically a p0300 ?
  7. JMoney02
    Definitely and are there codes as asked? Several issues were relate to this incident and its not the standard tuneup parts. What have your specifically changed recently? At 70mph it smooths out, but when you idle do here a "Vaccuum leak" or a unusual sucking sound?
  8. jhc
    jhc New Member
    Same rough idle with my 99 Suburban
    Same rough idle with my 99 Suburban and the P0300 code keeps popping up. Plugs, wires, cap, have all been changed.
