Running amp wire in an 03 siverado?
Discussion in 'Audio, Video & Gadget Tech' started by Schmig, Jan 10, 2010.
  1. Schmig
    Schmig New Member
    I have a 2003 Silverado 1500HD Crew Cab and i dont know where to run the amp wire from the battery to the amp. I was wondering if i could get some ideas from people that have ran the amp wire in this type of truck. Any replies and advise will help.
  2. Nickw059
    Nickw059 Member
    I have an 04 silverado EXT. cab. I ran my wires up through a rubber gromet that is located in the drivers side (Where you put your feet) underneather the carpet. its really simple
  3. TritonBoulder47
    I did this same thing, except I drilled a new hole...
  4. offroadaddict
    offroadaddict Rockstar
    I made a little slit in the grommet that the trans shifter cable goes through on the floor.
  5. Tdaz250
    Tdaz250 Rockstar 100 Posts
    I drilled a hole up like under the emergency brake through the fire wall and it comes up on the corner under the hood, right next to the battery.
