sad failure
Discussion in 'Photo & Video Gallery' started by blansho, Nov 24, 2009.
  1. blansho
    blansho New Member
  2. unplugged
    Sorry......I don't do Facebook. Post your pics and comments on this forum and share them with everyone.
  3. Eddie Z71
    Hi, and welcome to the site!:glasses: I'm not sure whats going on with your truck?
  4. blansho
    blansho New Member
    sorry theres the video now in youtube well it goes well in 1st gear but when it reaches 5000rpm it stops and the others
    gears lack of power u.u
    [ame=""]YouTube- camionetita fallando[/ame]
  5. s5belford
    s5belford Epic Member 5+ Years 1000 Posts
    doesn't look very good, wish I could help. Hope all turns out well
  6. Jimmiee
    It looks like the transmission is not up shifting. Then the rev limiter kicks in and kills the engine. First thing to do is check for trouble codes.
  7. dirtplay1975
    dirtplay1975 New Member
    check your fuel pressure, i know this sounds funny but i ran into this with my moms blazer, it would run good untill u stepped into it then it sounded like it reved up but wouldnt accelerate. ended up being 5psi low on fuel pressure, new pump problem solved
  8. 2009silverado
    2009silverado Rockstar
    I see there is a check engine light on the dash. I think you should do like Jimmiee said and run a code check on it. Need to get to a computer to hook it up. IE a mec shop or dealership.....Hope you figure this out...
  9. Viper
    Viper Rockstar 100 Posts
    I agree with checking the codes as the truck is probably in limp mode for which ever reason, are you flooring it when this happens if so does it do the same thing when you drive 'normally'?
