Sagging driver door
Discussion in 'General Chevy & GM Tech Questions' started by mayo, Mar 29, 2010.
  1. mayo
    mayo New Member
    The driver side door on my truck is sagging and I purchased replacement pins and put them in but one of the holes is worn to much so the pin doesn't press in. Is is possible to buy oversized pins anywhere or am I going to have to fab one up myself. I saw there is replacement hinge kits on Ebay but seems like a lot of work to grind off the old hinges and put new ones in. Any suggestions?
    BASSIST Rockstar 100 Posts
    Did you replace the bushings with the new pins?
  3. mayo
    mayo New Member
    Yes the holes are rounded to much for the stock size bushing.
  4. wis bang
    wis bang Rockstar 100 Posts
    Add a bead of weld to the worn area and re-drill the correct size...
