Serious oil leak, help.
Discussion in 'Chevy Suburban Forum (GMC Yukon XL)' started by 99burba, Nov 4, 2010.
  1. 99burba
    99burba New Member
    Was driving and noticed the CEL started flashing. It only flashes when I go over 30mph and then goes back to solid when I go below 10mph. Anyway, everything sounds fine, no knocking or ticking, but when I got home I crawled under it and found a mess.
    Please have a look at the pictures and maybe point me somewhere to start. Looks like it is mostly between the oil pan and the transmission case.
  2. 2COR517
    I would have said oil cooler lines/oil filter adapter till I saw the last pic of the starter. Pretty sure the the oil pressure sender is at the back of the block, behind the distributor. I would start it cold, when the oil pressure is higher, and look around. Maybe get someone to rev the engine to 2,000 for a little more pressure/flow.
