Setting Base Timing on 1990 5.7 TBI
Discussion in 'General Chevy & GM Tech Questions' started by TBIMan, Jun 7, 2010.
  1. TBIMan
    TBIMan New Member
    Hi everyone,
    I just finished installing a TBI 350 from a 1990 C1500 into my LAnd Cruiser and I need to set base timing
    I need to know where 0 degrees is on the pointer.
    Can someone let me know which notch in the pic is zero degrees?
  2. scrappiedew1
    scrappiedew1 Rockstar
    just did my sons 1991 k2500 5.7 4x4 zero is right aroung that large mark that is were we set it . you have to do one more thing you need to isconnect the ecm UP ON THE LEFT SIDE OF THE ENGINE BAY YOU WILL SEE THE COVER FOR THE RELAY CENTER GO A LITTLE TO THE RIGHT THERE IS A LARGE CLUMP OF WIRES ON TOP OF THAT IS A ONE WIRE CONNECTOR THAT IS A TAN WIRE WITH A BLACK STRIPE THIS NEEDS TO BE DISCONNECTED IT JUST UNCLIPS . THE RUBBER BOOT TO KEEPWATER OUT IS GREEN SO THAT WILL HELP YOU FIND THE RIGHT ONE IT IS JUST TO THE RIGHT OF THE RELAY PANEL UNDER THE HOOD. IF YOU HAVE A HAYNES MANUAL OTHER WISE YOU WILL BE TRYING TO TIME IT WILE THE ECM IS TRYING TO ADJUST
  3. TBIMan
    TBIMan New Member
    Thanks!
    Bryan
  4. scrappiedew1
    no problem ,hoped it helped
