Shock Absorbers?
Discussion in 'Chevy Silverado Forum (GMC Sierra)' started by 1500ExtChevy, Apr 22, 2010.
  1. Conlan Rose
    My Bilsteins Have lasted 202,000 miles and likely your truck also has factory Bilsteins. They are built to last, ride smooth, and are proven to be the best shocks for these trucks.
    UPDATED
    Realized I should mention that After 202,000 miles the truck still rides smooth on the road and on rough terrain you can barely notice the bumps. Only problem I have with the shocks is after 202,000 miles the truck is boatish because the shocks are soft and my rear has sagged a bit, yet the shocks wern't built to last that long so not the fault of Bilstein. I plan to install new Bilsteins in May because my factory ones make me trust the new ones will last just s long and ride just as well.
  2. TimTom64b
    Most any aftermarket shocks will be an improvement over stock. I like Fox and ReadyLIFT... a little pricey but awesome shocks.
  3. Pikey
    Just put bilsteins on my 2005 yukon xl. They are awesome!! Best shock i have ever had on a vehicle.
  4. ChevyFan
    Ranchos all the way.
  5. Scott_03silverado
    Scott_03silverado New Member
    i have a 03 silverado z71 and just put on bilstein 5100s on all four corners and LOVE THEM!
  6. Jeff Dodson
    Jeff Dodson Member 1 Year
    I just bought the MONROE REFLEX. Seem fine to me, on a 4x4 the suspension is stiff anyway... These are fine unless you rock crawling or building a PRERUNNER... THAT IS ON STOCK SUSPENSIONS anyway
  7. Pikey
    I had a set of monroe reflex on my 2005 yukon xl 4x4 with stock suspension for less than a year. I took them off to put the bilsteins on and they were shot. Very slow return and "skipping" as you pushed them in. You could hear oil passing the piston. The parts store warrantied them for me and I am going to sell them on cl. I had originally put the reflex mono tubes on. They stayed on for a day. They rode like complete crap! Then I went with the regular reflex. I thought that they were great, until I rode on my bilsteins. The monroe were ok for a month of so, then the body roll on my truck became pretty severe. I will never install a monroe product on my vehicle again. The manager at the parts store said that they see them exchanged under warranty more than any other shock they sell.
  8. j cat
    if the rear is sagged best replace the rear springs before replacing the shocks. with the vehicle not properly leveled out the U joints get damaged ..
  9. Conlan Rose
    I will be fixing the sagging problem at the same time I'm doing the shocks. Luckily the rear has only sagged to the point that the truck sits level, which is about 2 inches. I will be using Roadmaster Active Suspension to help the springs remain arched in the factory shape instead of almost flat like they are now. I have kept a constant eye on the u-joints and they have remained in great shape for being factory components.
  10. cmcolfax
    cmcolfax Rockstar
    Rancho's are notoriously stiff.
    Bilstien's are notoriously expensive.
    I always liked ProComps or TrailMasters on my Jeeps.
    Been running Monroe Gas Magnums in my F150 for some time and like them.
    Stiff enough, yet responsive and not bouncy.
    Prolly what I'll be putting in the Burb.
    -cmc-
