Shock help
Discussion in 'Maintenance & Upkeep' started by lsutoms, Jun 23, 2012.
  1. lsutoms
    lsutoms Rockstar 100 Posts
    I have a 2009 silverado 1500 lt with the 5.3L flex fuel. I'm ab to roll over 70,000 miles and I've noticed my ride seems more bouncy ESP when hauling trailers which is pretty regularly. Could my shocks be worn out already? If so what shocks should I replace them with? Should I put heavy duty shocks since I'm hauling regularly and also put load leveling air bags? Or maybe just heavy duty shocks. I also thought about putting regular shocks that are close to my stock ones and putting air bags. I have an onboard air system so the air bags would only run about $230. Any help would be great! Thanks!
  2. lsutoms
    I should also add that I'm running 295/70/17 Toyo mt's. Thought that this combined with hauling could be a reason that they would be worn out already
  3. 99'HEARTBEAT
    As you Regularly Tow and Haul Trailers, and having 70K Miles and now your ride is now more bouncy, its possible your Shocks could be worn out??.......going with Air Bags as much as you Tow/Haul, would be the way to go, along with a Set of New Shocks,
    I'm running with Edelbrock IAS Shocks and Air Lift Rear Air Bags, and with this setup......the Ride Comfort and Handling is Excellent when Towing, also having a On-Board Compressor, along with the Gauge and Controls in the Cab, this allows me to Adjust the Air Bags for the Change in either the Ride or Road Conditions.....
  4. reggiecab2000
    also check out Bilsteins HD shocks, but airbags for sure for your towing needs
  5. steved
    steved Former Member
    Airbags can negatively affect the ride by making it "pogo" more...I have had this happen when loaded heavy and a lot of air in the bags. They seem to amplify the rolling bumps...
