Sierra transmission acting strange
Discussion in 'GM Powertrain' started by GAPartsMN, Feb 24, 2010.
  1. GAPartsMN
    GAPartsMN New Member
    So I have a 1999 Sierra 5.3, I had the transmission rebuilt in October. Last week I was driving and lost all gears, no slipping, just like the truck was in neutral. I get the truck towed home, all of a sudden I have a transmission again. I am able to drive about 2 miles and I loose everything again, shut the truck off, restart a few minutes later and the transmission shifts fine again and then the cycle starts over. Anyone have any ideas on what the problem may be?
  2. Joeairforce
    Need to get it scanned for codes......
  3. GAPartsMN
    I am waiting a few days to get a Tech II scanner. Just looking for some ideas before then.
  4. Gambit
    Gambit Rockstar 100 Posts
    sounds like maybe your linkage wasnt adjusted properly? If it feels like it is slipping into neutral it probably is. Did you get a warrentee on the rebuilt tranny?
    When it loses drivability is it after going over a bump or something? That could lean even more towards the linkage not being adjusted properly. next time it happens throw the gear selector in neutral and pop it back to drive see what happens or go for the lower gear selections.
  5. GAPartsMN
    I have a warantee on it. The truck is currently with the rebuilder. The problem just happened and the truck is basically undrivable now, There is no pattern as to when it happens, just seems to after about 2 miles. You can shift the lever and it won't go in any gear. You shut the truck down for about 2 minutes and you are good to go another mile or two (shifts just fine in that time frame)
  6. Gambit
    You gotta love electronic transmissions.
  7. GAPartsMN
    ..or not. Hopefully I will get it figured out soon. Had to buy a Cavalier Z24 to get me around until I get my truck back.
