Silverado Clacking noise. Help?
Discussion in 'GM Powertrain' started by miamifire41, Feb 14, 2010.
  1. miamifire41
    miamifire41 New Member
    Hey everyone, I've got a 2000 silverado 5.3 with 80,000 miles on it. I was running 5w-30 in it and I was noticing substantial lifter/piston noise on startup, so I switched to 10w-30, Hayes manual says its ok in warmer weather, I live in miami. the start up "clacking" deminished but I noticed when Im cruising at 65 - 70, I hear a ticking noise.
    Question is, is that a lifter acting up or is it the "piston slap" that I read people talking about? and is it an issue? I'm figuring that its just loosening up internally a bit... No smoke, blow by, and I dont loose any oil..
  2. 383man
    383man Epic Member 5+ Years 500 Posts ROTM Winner
    its probably lifter slap, but could also be pinging due to using low octane fuel, try premium on a tank and see if it goes away.
  3. k.daddy1
    k.daddy1 Rockstar 100 Posts
    This is a common problem on the earlier 5.3 liter engines. The lower end tolerances were a little loose as far as piston slap, valve train noise is concerned. GM engineers have said it's nothing to be concerned about, the engine won't come apart, but they have recommended to start and run at an idle for approx. 20 seconds before putting a load on the engine.
  4. 1fast1500
    1fast1500 New Member
    ya mine does that to.. thanks for the info guys makes me feel better
