Sirius Radio 05 Silverado
Discussion in 'Audio, Video & Gadget Tech' started by silversurfer, Feb 14, 2009.
  1. silversurfer
    silversurfer Member
    I have had Sirius for several years, had the old model Stratus and the other day the wiris rubbed through - it was going to cost 50 bux just to replace the wires so I figured I would go ahead and upgrade my radio.
    I got the Sportster 5 which is very cool, has live radio replay and rewind and ( cool factor ) you can change the colors - has about 16 different color combinations so you can match your dash lights, or mood, or whatever!
    anyways - my old Stratus worked well - had a little bit of static noise which I fixed by that little coiled wire you can buy off eBay for less than 20 bux. This new radio, I have hooked up the same as my old radio - and I hear shhhhhh sound in the background :grrrrrr: So I installed the FM antenna extender ( just a wire which mounts on the inside of the window and connest to the radio.... STILL hear the sssshhhh
    so I am thinking I am going to have to break down and pull out the stereo and connect the direct-connect to the Chevy radio and the Sirius radio.
    How difficult is it to remove the factory radio? Is there a link to a web page or step-by-step?
    thanks for the help!
  2. tlperry68
    I have a sportser I would have given you. I don't use it any more.
  3. silversurfer
    silversurfer Member
    arrggg!! that sucks - I just spent 180 bux @ Best Buy!!
    Did you have yours wired directly into the radio?
  4. leadpan101
    leadpan101 Rockstar
    I dont know if it will work with your, i had sort of the same problem i just took my antenna off, and problem went away. just something to try.
  5. silversurfer
    silversurfer Member
    hmmm.... I'll go outside and give it a shot... couldn't hurt.
  6. silversurfer
    silversurfer Member
    makes it better but it's still swoooshy static sounding.
    thanks for the tip. I really don't relish the idea of going to the trouble of removing the radio. Especially because the cheap old Stratus was so quiet ... so I upgrade to a super expensive fancy one which sounds krappy...
