Some oil filter comparison information
Discussion in 'Maintenance & Upkeep' started by Pikey, Jan 26, 2013.
  1. dsfloyd
    Fram also makes different filters with varying levels of filtration, drain back etc. I don't get the low end fram but I do buy the tough guard from fram.
  2. TimTom64b
    I have used the Bosch, mobile 1, fram and K&N. The main thing I look at is the anti drain back feature... helps to minimize dry starts. What I have settled on it the K&N... as I like the nut welded on it to help with removal.
  3. Cowpie
    Anti drain back is something to consider if the filter is mounted other than vertical. If the filter is in an upright or vertical position, then the oil is not going to drain out of it anyway.
  4. steved
    steved Former Member
    Anti-drain back has more to do with keeping the engine galleys/passages from draining out, than keeping the filter full of oil...
  5. Cowpie
    Now I am confused. The oil goes from the sump to the filter then to the engine then back to the sump. How is the filter able to keep oil in the galleries and up in the head? The oil is only going to be up to the lowest gallery in the engine, which is not much higher than the filter itself. That being said, the idea of "dry starts" is not really that big of an issue with modern engines. Truth be told, many just install a new oil filter on their ride without even pre-filling with oil when they do an oil change, and their engines last well over 200,000 miles. Unless an engine sits for an extremely extended period of time, the risk of damage from a "dry start" is remote. I understand your concern, but think it is nothing to worry about. I have taken several diesel engines well past 1 million miles without opening up the engine for more than valve adjustments and an occasional injector, without worrying about anti-drain back valves in filters. Same for my gas engines, of which none had the engine died off before the vehicle itself.
  6. McClintoc
    All I have ever used is Fram. I do use the Tough Guard on my truck but I have been using Fram on my truck for almost 13 years now and no issues. All my dad ever used was Fram and he has never had a car withy any engine issues. I stick with what works and Fram seems to work just fine.
    But, keep in mind, there are a LOT of other factors in how long an engine lasts and how well it performs; not just what oil filter you use.
  7. steved
    The oil filter places a restriction into the main oil passage, preventing the lines/passages from draining back into the sump due to siphoning. Without it, the oil ump would need to reprime every time...oil pumps are not a high volume pump, and that process takes a while; not to mention filling all the passages.
    Have you ever started an engine where the ADB valve has malfunctioned? It can take more than a minute for the oil pump to reprime and push oil through the system until you see oil pressure...
    I'm done with this conversation.
    - - - Updated - - -
    At one point there was a quality control issue at Fram, and their filter caused a lot of failed Cummins engines...they were not designed for the added heat and pressure of the redesigned 1998.5 engine. Dodge even had a TSB that was a list of "approved" filters for use on the Cummins' used in Dodge.
    And that sort of caused the whole "Fram is garbage" debate...prior to that, I used Fram and never had an issue either.
  8. motorking
    motorking New Member
    You do realize that not only is this 19 yr old misinformation, most if not all of those filters have changed construction and manufacturers several times since this "study" was published. This study proves absolutely nothing about actual oil filtration as there is no part of it where oil filter tests are actually run.
  9. Pikey
    How do you see it as 19 year old info when they study was published in 2008? It was originally posted in 1999 and has been updated frequently since then. Nope, it does not say where the test was done at. If you read the FAQ the guy says that he is an Electrical Engineer with no filter experience, just a common sense approach. He never says how well it filters, just the number of pleats and length of the filter media. It is on the internet, so who knows how true it is. Just like anything on the internet. Anyone can post anything. If you have "more reliable" info then please, by all means, share it with us.
  10. motorking
    Pikey,
    I work for FRAM Filtration. We publish (right on the box and on our website) both the efficiency (@ 20 microns) and capacity (in mileage) of our filters using the ISO 4548-12 tests with the correct particle size dirt. This is the only OE automaker accepted test for oil filter validation. We test with dirt in the 10-20 micron particle size as that is what the test calls for. We publish our efficiency at 20 microns. Many oil filter companies will use the ISO test and skew the results by using larger (25-30 micron) particle size so they can claim a high efficiency rating. This is on our box and I can tell you the FTC and our competitors would be all over us if we published claims we couldn't back up. The real proof of filter quality is having oil analysis performed to actually see how well your filter is working. FRAM filters always do well in these tests. Look up Scott Lipford on youtube, a real GM truck story that is now sporting 550k miles and still going strong.
