spare tire pole
Discussion in 'Chevy Silverado Forum (GMC Sierra)' started by 9191gmc, Sep 23, 2009.
  1. 9191gmc
    9191gmc Rockstar 100 Posts
    01 silvy long bed
    My rig doesnt have a pole to get the spare out from under the bed. I got a pipe here that fits and have ground this end on it. Doesnt work yet.
    Can someone look at there pole wrench for this model and show with measurements how it has to be to engage the up and down pulley on the thing. Here is what I have so far....
    Otherwise its stuck up there...
  2. vncj96
    it needs a longer angle, and it also needs to be tapered a bit.
  3. Mean_Green_95
    you are using the wrong end. You need the square female end to slide in first to lower the tire.
  4. seffieldvillage@aol.com
    seffieldvillage@aol.com Rockstar 100 Posts
    hi i could be wrong but dont you use the jack handle
  5. s5belford
    s5belford Epic Member 5+ Years 1000 Posts
    I thought you were just suppose to use the jack handle too, but on my moms 02 silvy you have to remove that plug next to the license plate with the ignotion key and to lower it faster I put a flat drill bit into the drill and it lowers it REAL fast. Hope this helps.
  6. seffieldvillage@aol.com
    hi i would look in the owners manual. it will tell you what to use. ralph
  7. 9191gmc
    it was all broken up so I cut the cable and threw out the whole works. The spare can live in the bed.
  8. CarpenterGuy
    CarpenterGuy Epic Member 5+ Years 500 Posts
    haha that sounds like it'll work fine.
  9. s5belford
    haha, thats awesome! sounds like something I'd do!
