Spark control module location?
Discussion in 'General Chevy & GM Tech Questions' started by 85 Silverado, Oct 29, 2009.
Newest Photos
  1. 85 Silverado
    85 Silverado New Member
    Can someone tell me where the Spark control module is located on a 1985 Chevy C10 P/U with a 305 V8? Thanks!!
  2. unplugged
    unplugged New Member 1000 Posts 100 Posts
    The control module is inside the distributor. Looks like this:
    [​IMG]
  3. 85 Silverado
    That is not the module i'm refering to.But, thanks for the reply! This module plugs into the distributor. I think it is under the dash or on the other side of the firewall.I just can't find it!!!:grrrrrr:
  4. Jimmiee
    Jimmiee New Member 1000 Posts 100 Posts
    The 4.3L is behind the distributor on the air pipe.
    The 5.0L is on the brake pedal bracket according to Mitchell.
  5. 85 Silverado
    :great:Thanks for the info. Hopefully this will cure my problem. I'll post my results. - John
  6. 85 Silverado
    The spark control module is forward of the glove box on my 85 C10. I'm swapping out SCM today.
  7. 85 Silverado
    Replaced Spark Control Module. Truck runs great!
  8. 85 Silverado
    Wake up this morning & truck would not start. Having the same problem - No Spark! WTF!!!! :grrrrrr:
    Could a weak battery be causing this?????? Anyone?:confused:
  9. Jimmiee
    Check the power and ground to the spark control module while it won't start. If you suspect a bad connection you can jump power or ground or both to the module as a test.
  10. 85 Silverado
    It Looks like a connection problem. if i reseat the connector on the SCM, the truck will usually start and run for a day or two, then dies again.
