Spark plugs for a 2005 Tahoe
Discussion in 'General Chevy & GM Tech Questions' started by bbmctahoe, Dec 7, 2009.
  1. bbmctahoe
    bbmctahoe New Member
    Please tell me the proper AC Delco spark plug for my 2005 Tahoe gas engine. It has about 92K miles on it so i expect it is about time to change them????? Thanks for your help.
  2. 99'HEARTBEAT
    ......If you have the 4.8 or the 5.3 Liter,Then you would get the A/C Delco Iridium Plugs and they Should be Pre-gaped at 0.40.....but Check to make sure, Also take a look at your Plug Wire's.....It may be time to replace them as well.
  3. bbmctahoe
    Thanks for the info. Is tehre a part or plug number?
  4. 99'HEARTBEAT
  5. bbmctahoe
    Thanks so much. The truck runs fine but has 92K miles on the plugs. Should I change them??
  6. 99'HEARTBEAT
    For me its Tough Question to Answer....you are in a Better Position as to How your Tahoe is Running....I changed mine Plugs at around the Same Mileage you have on Your Ride, along with a New Set of Plug Wires.
  7. bbmctahoe
    Thanks...I just like to be pro active. Any ideas about changing bkake pads??
  8. 99'HEARTBEAT
    Regarding the Brakes...Are you having any Problems with them???.....again you've got 92k on your Tahoe,...It may be time for New Pads.
  9. bbmctahoe
    No problem with current pads. Still have some life in them but want to change before it is critical to do so. Any threads/pictures on how to do it on a 2005 Tahoe? Thanks again so much for your help.
    Where is the best place to buy the new plugs??
  10. 99'HEARTBEAT
    In my Reply Above...Summit has Good Prices......If you do a Search at the top, there is may be a Few Threads on changing Brake Pads.
