speed sensor or abs sensor
Discussion in 'General Chevy & GM Tech Questions' started by vncj96, Mar 25, 2010.
  1. vncj96
    My abs and brake light is on I crawled under there to look and the wire had been sliced and the plug and a few inches of wire was missing, my question is are the speed sensor and the abs light one in the same or two different sensors. I just got this truck so do not have a manual yet. 99 silverado reg cab
  2. BadBurban98
    BadBurban98 Rockstar
    wheres the broken wire the front or tranny or rear the brakes light is usually fluid or the parking brake is on the abs only will go on if the abs is malfunctioning
  3. vncj96
    Its at the front left wheel
  4. BadBurban98
    that will be your abs sensor in the hub that will cause that abs light to be on now where was it sliced the harness on the car or the harness before the plug on the sensor side?
  5. vncj96
    Thanks! Thats what I figured but you never know.
  6. BadBurban98
    Notta problem bro
  7. vncj96
    So the actual brake light should just be for the fluid being low then?
  8. BadBurban98
    yeah i'd check the fluid level and if its still on i'd check out the parking brake release switch
