spun rod bearing
Discussion in 'GM Powertrain' started by somonenew1994, Jun 3, 2010.
  1. somonenew1994
    somonenew1994 Member
    what would cause me to spin my rod bearing i just reringed the motor and repalced them and now they are spun could i of done something wrong? or what causes that to happen
  2. 2COR517
    Did you replace the bearings with new when you did the rings?
  3. somonenew1994
    yes that is what is throwing me off most of them are bad like i ran it without oil but i have always had oil in there
  4. somonenew1994
    than would a 2001 motor mount in that 97
  5. 2COR517
    Did you use Plasti-Gage to measure the clearance when you did your bearings? I presume you had oil pressure?
    I'm guessing your current motor is a 350? A newer 350 will go in no problem.
  6. wis bang
    wis bang Rockstar 100 Posts
    Did you check the bearing clearance w/ plasti-gauge? it helps you determine if you need oversize bearings to make up for journal wear. Installing new standard bearings against a worn journal leaves the room for them to spin...
  7. starsilverado
    starsilverado Rockstar 100 Posts
    didn't put them in backwards did you?
  8. somonenew1994
    alright so hear is the deal they were just faulty bearings i called the company i got the from and they said this isnt the first time this has happen. So i priced out to get my crank turned which is going to cost 100 and than another 80 for all new bearing or i could get a autozone reman for 175 with all the bearing so looks like i am going to be going to auozone soon
  9. phoebeisis
    If money wasn't a problem-ha,ha like that is ever the case- you can buy a brand newGoodwrench GM motor 5.7 for either a TBI(95 and earlier) or the 96-99- for just $2150!!!
    This is the HUGE advantage owners of "older" GM trucks have over owners of anything else. We can buy -NEW, GENUINE GM NO CS CUT RATE PARTS- motors for cheap prices.Heck, you can get a new GM motor new GM trans for about $4200-try that with anything else.A Toyota would cost maybe $12000 for same,same, Ford or Dodge maybe $8000+. It is actually worth replacing the drivetrain of an old GM(with a good body, not one of those NE or Midwest rust buckets-no offense to you snowbelt guys)- never worth it with other brands.
    Yeah- $2150 whole new motor-just bolt on your dist, water pump accessories, gaskets and off you go.
    New heads, new crank, new everything-no worries about having to redo heads, or rings, bores, valve guides, valve guide seals.No worries about Chicken S&%$ aftermarket bearings, or machining the crank just right.
    Unfortunately, $$ is usually a problem, and $175 beats $2150.
    Someday,I would like to replace my 1998 Suburban's 5.7(213,000 miles) with a new Goodwrench.It still runs great, no oil use, great mpg(hy), but 200,000 miles is plenty of miles.
    Broke now, so the motor will have to wait.
    Good Luck with your motor
  10. wis bang
    That works, especially if you plan on keeping the truck! I put a GMPP HT3.4L crate engine in my S-10 after the original 2.8L developed a rod knock at 196,269 miles.
    It was dad's truck and I knew what he had replaced and I figured the $1,800.00 for the longblock crate would give me a good 6 - 8 years instead of spending the same on another truck that could/would develope a similar problem in a few years.
    I ran it another 7 years b/4 the rust got ahead of me and sold it w/ 306.000 miles on the rest of the running gear. W/ the new clutch & fluids the swap cost me around $2,200.00 or just a little over $700.00 a year.
    Three years later the guy I sold it to 'bought' an inspection sticker and is still using it for a short commute and to haul around home improvement items. I think he had to do a fuel pump & a cheap set of Pep Boys tires...
