Squeaking problems
Discussion in 'Lifted & Offroad Suspension' started by whodeywhat, Sep 26, 2012.
  1. whodeywhat
    whodeywhat New Member
    I have an 08 silverado 4wd reg cab. i had a rough country front end leveling kit installed in july. ever since then there has been a squeaking and creaking noise coming from the front when turning and normal driving. also recently when i go in reverse there is a loud squeaking noise that is just embarrassing. does this have to do with the leveling kit? should i remove it? or does something need to be greased to stop this? please help
  2. Pikey
    Check your u-joints for the noise in the rear. I am not familiar with that kit, but I would go ahead and grease all the zerks in the front (ball joints, tie rods, idler, pitman) Then I would spray some lube on the control arm bushings and see if that helps.
  3. Pikey
    Did you get the squeak to stop?
  4. whodeywhat
    Yea I was finally able to get it to the dealership and they said the u joint went out and while I was there he said I had 3mm left on breaks so perfect timing I guess but thanks for the help
