Starting Issue's....Need Help
Discussion in 'General Chevy & GM Tech Questions' started by Kingdaddy1, Jun 25, 2012.
  1. Kingdaddy1
    Kingdaddy1 New Member
    I have a 96 Sonoma with a 4.3 in it and I'm having starting issues.I checked plugs,coil pack,cam position sensor new,ignition control module new,crankshaft sensor runs great but would give a little trouble starting when cold after that it would run good and start normal.I didn't drive it for a few days then went out to go somewhere and it would not turns over but no bite.I was doing some research and saw something about spider injectors being bad.Has anyone had this problem that can give me some quick tips before I pull this apart.
  2. SurrealOne
    We are the Borg. Lift your vehicle and surrender your keys. We will add your biological and technological distinctiveness to our own. Resistance is futile. Erm, I mean ... welcome to GM Truck Club! :great:
    If you don't get an answer within this thread in the next day or so I recommend posting your inquiry in the 'Technical Forums' section of the site -or- the 'GM Platforms' section that is specific to your vehicle. You'll reach a wider group of the forum members that way ... and target your inquiry more directly to those who might already have experience with it.
  3. donyms
    Welcome to the club and good luck with your problem, It's good to have you aboard. :glasses:
    ***Thread Moved to General Tech Q&A Section***
