Starting issues
Discussion in 'Chevy Silverado Forum (GMC Sierra)' started by eyegore, Jun 6, 2013.
  1. eyegore
    eyegore Rockstar 100 Posts
    '07 Silverado occasionally has starting issues. Won't turn over. Nothing. Just starting to flash "service anti theft deterrent system". What's up with that? What can I expect when I take it to the garage and would I have to service it at a Chevy garage?
  2. j cat
    when you turn the key to start with the headlights on what happens ?
    starter solenoid could be bad/loose wiring to it. battery should be load tested .
  3. nonnieselman
    nonnieselman Member 1 Year
    starter relay could be bad also.. key energize the relay which energizes the starter solenoid.
  4. eyegore
    Has a 1 yr. old battery. Last month inspection there was a loose wire on the starter. That got tightened. Sometimes there is an audible click then nothing. If I pull the key out, then try again, it starts. Flashes the service theft deterrent system. If I hit the OnStar when it happens again, would they be able to diagnose the problem?
