Steering column cover removal??
Discussion in 'Chevy Suburban Forum (GMC Yukon XL)' started by wreckwriter, Jan 15, 2010.
  1. wreckwriter
    wreckwriter New Member
    Hi guys, I have a 2001 Suburban K2500 8.1. My tow/haul mode is not working and research has indicated most likely cause would be a broken wire where the shifter meets the column. Problem is that I can't figure out how to get the plastic trim cover off.... Expected a couple screws but, while there are holes they don't appear to contain screws.... Anyone done this job?
  2. wreckwriter
    Does the steering wheel have to come off to do this???
  3. wreckwriter
    OK, figured this out. The trick was to remove the knee bolster first. Doing this enabled a better grip on the lower cover which then snapped right off. Sure enough, broken wire. A quick solder job and everything works.
