Steering wheel moan when turning
Discussion in 'General Chevy & GM Tech Questions' started by SurrealOne, Mar 27, 2012.
  1. JnBama
    JnBama Rockstar 4 Years 500 Posts
    my 2000 p/u steering moaned when during cold weather and so do I
  2. osgprometheus
    osgprometheus Rockstar 100 Posts
    Check the dust seals around the shaft. I had a truck come into the shop with the same problem and it ended up just being the column shaft rubbing on some rubber.
  3. SurrealOne
    Anything in particular to look for?
  4. osgprometheus
    The truck that came in had tilt steering. Where the tilt dust cover went under the top side of the column into the dash was rubbing on the shaft.
  5. SurrealOne
    I've got tilt, as well. I'll check this.
  6. osgprometheus
    Let me know. I'll hop back on to see what you came up with.
  7. domano 68
    domano 68 New Member
    Did this fix the issue? Could you post some pictures of the area you are supposed to inspect please? Thank you!
  8. Pikey
    I had the same issue on my 05. I tore apart the column and found nothing. I had a warranty on it and found a small leak in the steering gearbox. I had them replace the gearbox and to my surprise the moan stopped immediately. It really sounds like it is in the column, but the sound travels up the steering shaft.
  9. TimTom64b
    My son has this same issue.... we replaced pump still problem still exists. My mechanic friend says there is a valve on the pump or something that controls the fluid flow. Since we reused everything but the pump my guess is our problem is the valve. This maybe what everyone else is experiencing.
  10. Pikey
    I replaced my pump also, no change. it was a valve inside the gearbox.
