still rubbing
Discussion in 'Lifted & Offroad Suspension' started by jerrynino, Dec 26, 2008.
  1. jerrynino
    jerrynino Rockstar ROTM Winner 100 Posts
    ok so like my sig says, my 285's still rub after the leveling kit i put on. my wheels are 9'' wide so i think thats the problem with the offset ive got (-12 i believe).
    if i get some wheel spacers to push the wheel out a bit will that solve my problem?
    if so what size spacer should i get 1'' or 1.5''?
    last question... i used hubcentric rings for my wheels... so the spacers need have a 78cm bore which is stock or will it be different?
  2. jiujitsu
    jiujitsu Rockstar
    i had to trim a lil plastic on the bottom did you do that?..i have 285 70 17 and mine sometimes will rub a tiny bit when i reverse but everyone i know had to trim a lil
  3. tbplus10
    Before you start spending money to get rid of the rub see if it can be fixed with a BFH or some plastic trimming. Get in the wheel well and find where its rubbing and see if you can trim or bend things back a little.
  4. jerrynino
    i actually did trim already but the part that is rubbing on is the actual metal... i had a local shop cut off a piece but it still rubs a bit... i dont like it rubbing... any other suggestions guys?
