Strange Noise
Discussion in 'Chevy Silverado Forum (GMC Sierra)' started by Silver Chevy, Nov 19, 2011.
  1. audible
    audible Member
    Please let me/us know what they do for you and if it works...........this will set precedence for the rest of us to get resolution.:great:
    Thanks,
    Audible
  2. Silver Chevy
    Silver Chevy Member
    Left the truck at the dealer today,,, they came up short, I have to bring it back, there going to call the tech from gm to check it out,,,,big pain in the a$$
  3. audible
    audible Member
    Keep after them...if they are bringing in a tech...they know there is an issue, just not how to fix it. Keep us posted.
    Thank you,:great:
    Audible
  4. Silver Chevy
    Silver Chevy Member
    Yes for sure ,,,,
  5. jfeezie
    jfeezie New Member
    I took it upon myself to preform this TSB on my truck myself. No more noise!
    TECHNICAL
    Bulletin No.: 08-08-48-003F
    Date: April 06, 2011
    Subject: Tapping, Clicking or Ticking Noise at Windshield Area (R&R Right and Left Windshield Side Reveal Moldings to Add Double Sided Tape)
    Models:
    2007-2012 Cadillac Escalade, Escalade ESV, Escalade EXT
    2007-2012 Chevrolet Avalanche, Silverado, Suburban, Tahoe
    2007-2012 GMC Sierra, Sierra Denali, Yukon, Yukon XL, Yukon Denali, Yukon Denali XLSupercede:
    This bulletin is being revised to add model years. Please discard Corporate Bulletin Number 08-08-48-003E (Section 08 - Body and Accessories).Condition
    Some customers may comment on hearing a tapping, clicking or ticking noise at the windshield area. This condition occurs more frequently while driving at highway speeds and could be exaggerated on vehicles with front bug guard deflectors.
    Cause
    This condition may be caused by air/wind causing the windshield side reveal moldings to move, generating a noise.
    Correction
    Remove both windshield reveal moldings, add double-sided tape and re-install the moldings following the steps below:
    [TABLE]
    [TR]
    [TD]1.[/TD]
    [TD]Using tape (1) or a grease pencil, mark the position of the inboard edge (2) of both left and right reveal moldings onto the windshield, following the contour of the molding.[/TD]
    [/TR]
    [/TABLE]
    [TABLE]
    [TR]
    [TD]2.[/TD]
    [TD]Remove the left and right windshield side reveal moldings. Refer to Windshield Side Reveal Molding Replacement in SI.[/TD]
    [/TR]
    [TR]
    [TD]3.[/TD]
    [TD]Being careful not to affect the tape or grease pencil marks, clean and prep the glass at the seal interface with Glass Adhesion Promoter, P/N 12378555 (in Canada, use 88901239).[/TD]
    [/TR]
    [/TABLE]
    [TABLE]
    [TR]
    [TD]4.[/TD]
    [TD]Apply 3M Automotive Adhesion Promoter 06396, or equivalent, to the underside of the reveal molding seals.[/TD]
    [/TR]
    [/TABLE]
    Tip
    An approximate 600 mm (24 in) length of tape should allow for overlap at the top to be trimmed back leaving a tail of release liner (1) and, at minimum, should reach the fender cut line at the bottom.
    [TABLE]
    [TR]
    [TD]5.[/TD]
    [TD]Apply a 600 mm (24 in) length of 3M Automotive Acrylic Plus Attachment Tape 06386 (1.14 mm (0.045 in) thick x 6.35 mm (0.25 in) wide), or equivalent, to both sides of the windshield. Ensure the tape (1) position is centered between the windshield edge (2) and the tape/grease pencil line (3). Do not remove the release lining from the tape yet.[/TD]
    [/TR]
    [/TABLE]
    [TABLE]
    [TR]
    [TD]6.[/TD]
    [TD]Reinstall the reveal molding to one side by sliding the molding downward and ensuring that the top lip is engaged at the upper edge of the windshield.[/TD]
    [/TR]
    [/TABLE]
    [TABLE]
    [TR]
    [TD]7.[/TD]
    [TD]Install the fasteners to the reveal molding, starting from the top. Refer to Windshield Side Reveal Molding Replacement in SI.[/TD]
    [/TR]
    [TR]
    [TD]8.[/TD]
    [TD]Lifting the top edge of the reveal molding, grab the tail of the release lining and pull downward removing the lining.[/TD]
    [/TR]
    [/TABLE]
    [TABLE]
    [TR]
    [TD]9.[/TD]
    [TD]Press or roll the reveal molding against the windshield ensuring adhesion of the tape to the glass.[/TD]
    [/TR]
    [TR]
    [TD]10.[/TD]
    [TD]Repeat steps 6-9 on the opposite side.[/TD]
    [/TR]
    [TR]
    [TD]11.[/TD]
    [TD]Remove tape or clean the grease pencil marks from the windshield.[/TD]
    [/TR]
    [/TABLE]
    [TABLE]
    [TR]
    [TD]12.[/TD]
    [TD]If positioned correctly, trimming of the double sided tape should not be necessary, however inspect the reveal moldings for any tape not covered and trim off any exposed tape.[/TD]
    [/TR]
    [/TABLE]
    Important
    After taping the windshield reveal moldings, avoid washing the vehicle as well as excessive contact with the windshield reveal moldings for a minimum of 72 hours.Parts Information
    3M(TM) products may be purchased through your local distributor. Information about 3M product retailers in your area may be obtained by calling 1-866-364-3577 (U.S. and Canada).
    Warranty Information
    For vehicles repaired under warranty, use the table.
  6. RCChevyGuy
    RCChevyGuy New Member
    is it worse/more common after or during a rain? i have had the same problem in my truck, i was told its due to a not quite perfect seal on an aftermarket windshield, i actually noticed water leaking in at the top of the windshield on the passengers side one day
  7. Pikey
    Your pictures don't match the words.
  8. jfeezie
    jfeezie New Member
    Well that is odd.... the did when I posted it....
    ---------- Post added at 12:17 AM ---------- Previous post was at 12:08 AM ----------
    I've added the photos in as attachments now, hopefully this will keep them from changing....
  9. BigDogTruck
    BigDogTruck New Member
    Strange noises (solved for me!)
    Hello everyone and Happy Holidays to the forum: After having my truck for a year now, I had the same noises coming from the windshield area on both sides of the windshield. 2010 Silverado Crew cab LTZ 4 x 4 Diamond White Pearl.
    This Summer it only happened a few times but the colder weather it happened all the time. I drive the Ohio Turnpike everyday at up to 75 - 80 mph and it does make noise.
    Finally I recently changed out my chrome 20" wheels and tires for my 17" snow tires and wheels(not related) to the noise but it is when I fixed the noise problem. After changing my oil and filter, I thought about the noise thing. ALL I did was get my black silicone in my caulking gun and raised the side windshield trim up slightly and injected the silicone into the opening between the windshield and the side trim. I then lightly pushed down the trim to seal it. I let it set over night and the next day "NO NOISE" at all. Hope this easy fix works for the rest of you. No need to remove trim, go through all the other steps listed in this thread, this does work and easy too!
  10. Silver Chevy
    Silver Chevy Member
    Truck is going in Tuesday I will let u know the results,,,,,
