Stuck in Four Low and need help
Discussion in 'GM Powertrain' started by CJ2012, Feb 25, 2011.
  1. CJ2012
    CJ2012 New Member
    i have a 1999 chevy silverado 1500 ls 5.3l Z71 4x4 and i was pulling on another truck and the truck snatched. at that point the truck was stuck in four low and cannot be removed from this position. i have replaced the fourwheel drive switch and that didnt work along with cleaning out the connections around the transfer case and the actuator on the front end. any ideas? service fourwheel drive light comes on every time the truck is cranked and when put in drive it lurches forward so you know it is engaged. it has the four button switch with auto 2hi 4hi and 4lo. any help appreciated ive searched all over the internet for about a week now and need help.
    thank you
  2. silveradotrailblazer
    Welcome to the club. Have you tried pulling the ses codes?
  3. cshoule
    cshoule New Member
    the electric 4x4 switch controls a motor behind the transfer case that switches from 2,4hiand 4lo, i have seen these motors quit and leave u stuck in 4x4.u can check by taking the motor(looks like a wiper motor) off and switching it from 4 to 2 and see if it moves. when u have it off u can also switch it back to 2wd by turning the gear that the electric motor came off of.if thats the problem. good luck.
  4. CJ2012
    CJ2012 New Member
    i tried removing the motor but i cant get to two of the bolts and seems to have a seal on it? i got an error code U1026 that came to be a sensor not sending a signal from the atc? does that mean im not getting power to the atc? it seems to shift into 4low everytime i shift into drive but i dont think the front hubs are locking in. at D2 i can get up to 15 but O/D i cant even get to 5 mph.
    thank you for your help it is much appreciated.
  5. 2COR517
    Do you have the transmission in Neutral when you try to shift the transfer case? Some guys have better luck shifting in and out of low range with the truck at a dead stop, others do better with the truck rolling very slowly.
  6. CJ2012
    CJ2012 New Member
    trucks in nuetral and have tried dead stop and rolling but the switch isnt even active. its a brand new switch but doesnt seem to get any power from the transfer case as far as a signal. have gone under and checked all my connections and they are all good fuses are good and couldnt find any relays relating to this problem.
  7. 87silverado
    87silverado New Member
    on my truck, i have an 01, i had a similar problem. it left me in nuetral when i tried to shift back to 2wd. the service light would come and all the push buttons lights would only come on when right when it started up and then they would go out. what it turned out to be was the transfer motor went bad on me. I had to take the front driveshaft out and get to it that way, other than that it was easy to replace.
  8. CJ2012
    CJ2012 New Member
    thats what i was thinking it was anyway to tell if the motors bad once you get it out?
  9. CJ2012
    CJ2012 New Member
    guess it was the encoder motor. took it off and turned the gear to 2hi and just been driving sense.. will order new part and assmebel soon and let yall know if it worked thanks for everything
