Suburban 6.5L Turbo Diesel
Discussion in 'Chevy Suburban Forum (GMC Yukon XL)' started by SweSuburban, Feb 13, 2012.
  1. SweSuburban
    SweSuburban New Member
    Hi !
    I´ve just bought my Chevrolet Suburban -1997 Turbo diesel , and I can´t get the turbo to charge , only when i pull the westgate tube .
    I´ve bought a new " cellunoid " ? and replaced it , still it won´t charge .. I´ve also checked the vakuum tubes and they seems to be fine.
    Also when I drive the 4L / 4H and the 2L / 2H switches keep blinking and it makes a wierd noise from the front wheels.
    Does anyone have any idea of what the problems can be ??
    Sorry for my bad english.
    / Dennis
  2. Joeairforce
    did you check to see how much vacuum the vac pump makes? It's a common problem for the vac pumps to fail.
  3. murdog94
    I second that..
    As to the 4wd problem, the noise and flashing lights indicate there is a problem. with the 4wd solendoids, i would disconnect the front axle solenoid to see if the lights quit flashing. if so then there is a short either in the switch, the wiring, or the solenoid in the front. (usually it is the solenoid)
  4. SweSuburban
    Thanks for the tips , im going to check it out as soon as i get to the garage !.
  5. SuperSport01
    SuperSport01 New Member
    I would delete the vaccum pump and boost solenoid, and install a Heath turbo master wastegate controller.
  6. Joeairforce
    When working properly the factory system is much better.
  7. SuperSport01
    ^That may be true for some but it works fine for me. I like the fact that I'll never have to install another vacuum pump or boost solenoid.
  8. SweSuburban
    I rather not get new parts as I live in sweden and parts for USA cars are hard to get, And if u somehow find what your looking for it´ll be doubled the price as it would cost in usa. I got a price from mekonomen ( our local part shop ) on a 5" lift kit , and that would´ve cost about 3200$ for my suburban if I done the work my self. I don´t know how much it would´ve cost to import tho, Does anyone have any idea what the price would be in usa ?.
    As regarding the turbo , the vacuum should be enough .
    If i pull off the westgate tube isn´t the turbo supposed to get full charge ?
    Anyone who has more ideas of how I could get it to charge ?
    Maybe the westgate is broken ?
    Also I had a thought about the "rods" inside the turbo might be broken so the gate won´t open / close ?
    / Happy for answer
  9. SweSuburban
    Got it fixed !
    There were holes in the front exhaust, so i welded it and now it runs fine.
    Thanks for all the answers tho !
