Suburban--Another Fuel Pump?
Discussion in 'General Chevy & GM Tech Questions' started by david78, Jan 19, 2011.
  1. david78
    david78 New Member
    I have a 1996 K2500,5.7,136,000 miles, automatic. It had been running great, but quit on the way home a couple nights ago, just like turning off the key. I have spark but no fuel. I can't hear the pump come on when I turn the key. When I put a jumper wire from the 87 to 30 terminals on the relay, I get 11+ volts at the connector where it plugs into the pump harness, but nothing from the pump. I just replaced the pump less than 2 years ago, but it sure seems to be the pump; although I had a lot of symptoms before the last one failed. Any thoughts? One thing that sort of puzzled me: I plugged the relay in but left it sticking up enough to touch the 30 and 87 prongs on the relay with my meter probe. I had 11+ on the 87 but 0 on the 30, with the key on, like it wasn't getting power through the relay. Could a bad relay be the problem? Thanks.
  2. stephan
    Just to be sure before you pull the pump, I would unplug the relay & bridge the wires & check for power at the pump.
    A better test is: If you have a long wire you could also just input power & a good ground at the pump connection itself. This would bypass & eliminate all possible wiring problems & be more definitive.
  3. david78
    david78 New Member
    That's a good idea; I'll give it a try. I'd really like to avoid laying in the snow dropping that tank, which of course has 30 gallons of gas in it. :grrrrrr:
  4. stephan
    You don't want to drop it with 30 gallons of gas in it David. Even with floor jacks & 2 guys helping you, it would still be dangerous cuz that's going to weigh 180 lbs for the fuel & another 30+ lbs for the tank, plus they are just plain awkward to handle with the fuel sloshing around & changing the balance... Just to be safe, borrow some gas cans & siphon it out if it comes down to replacing the pump.
  5. david78
    david78 New Member
    Yeah, I know. I was just referring to the hassle of draining all the gas. Last time, I filled my tractor and two cars and still had to put some in cans.
  6. david78
    david78 New Member
    I put a new fuel pump relay in today and changed the fuel filter and now the pump runs when I turn the key on. I have fuel at the test port (no gauges to test with). When I pour a little gas in the throttle body it will run until that's gone, then quits. Not sure where to go from here. Any ideas?
  7. stephan
    Get a helper to start it while you watch the injectors in the TBI. Watch & see if they spray when it's running. If no spray, then pressure could be too low & you will need to put a pressure guage on it. (you can borrow pressure guages at auto parts stores if you leave a $$ deposit.) If no spray, it could also be triggering problem, but I'm leaning towards fuel delivery since your relay got the pump running.
    **You also need to check & see if the pump is continuing to run when you release the key from the crank position to the run position.
  8. david78
    david78 New Member
    Well, it won't run unless I'm pouring fuel into the TBI, but while cranking I can't see any fuel spraying in. Can the pressure be tested while cranking, or does it have to be running? The new relay causing the pump to run without resulting in the motor starting suggests what?
  9. david78
    david78 New Member
    Well , I got a pressure gauge today and when I turn the key on I have 45 pounds. When I start cranking it actually goes down to around 40. The manual says 60-66, so I guess my pump is toast. Now comes the fun part. Thanks for all the replies!
  10. david78
    david78 New Member
    It was the pump. I replaced it yesterday and it started right up and is running fine. I got a Delphi for $157 shipped from Amazon. If you need a pump, that's probably the best deal you'll find on an OE pump.
