Suburban bad brakes
Discussion in 'General Chevy & GM Tech Questions' started by biggsmiley, Dec 29, 2013.
  1. biggsmiley
    biggsmiley New Member
    88 subby......brakes are bad.....pedal goes to the floor......if i slam on them i believe the rear brakes engage.....could it be air in the lines...HELP
  2. Pikey
    moved post to proper sub forum
  3. RayVoy
    Yes, if you had them apart. If not been worked on lately, you have a leak somewhere. Look on the ground/floor for a puddle of fluid, or crawl under and look at the inside of the wheels.
  4. poncho62
    poncho62 Active Member 2 Years 100 Posts
    Pop the top on the master cylinder and see if the fluid is way down. Id one side is empty, you likely have a leak. If its full, you may have a bad master cylinder....or air in the lines
