Suburban brake upgrade
Discussion in 'Lifted & Offroad Suspension' started by blcdog, Oct 16, 2009.
  1. blcdog
    blcdog New Member
    I have an 08 Sub LT that i'd like to modify a bit.
    Want to eliminate what I feel is brake fade. What's an easy, inexpensive way to better achieve reduced braking distance? Don't want to change calipers, but lines, pads etc...
    Don/t want to spend the farm as I have other mods to do as well. Safety 1st though.
    Thanks
  2. sc99z71
    sc99z71 Rockstar 100 Posts
    Take a look at EBCbrakes.com and check out their drilled and slotted rotors and the Yellowstuff brake pads. But if you like and want to buy, then go over to partstrain.com and get your EBC stuff they have great discounts on all EBC stuff!
  3. dsfloyd
    A good set of cross drilled slotted rotors and good pads
  4. vncj96
    Get steel braided brake lines, and replace the flex tubes, about a 100 bucks. Its the best place to start and can often be overlooked. It would be the same as having some awesome processor in your computer and only having dial-up access.
