Suburban Rear Window Washer
Discussion in 'Chevy Suburban Forum (GMC Yukon XL)' started by moosetags, Mar 5, 2010.
  1. moosetags
    moosetags Rockstar 100 Posts
    I have two Suburbans, an '04 and an '05. In the last couple of weeks, the rear window washers have quit working on both Subs. The wipers still works fine. The fluid tanks are full. I have used the rear washers regularly, and they both always worked in the past. It seems odd that both quit working at t he same time.
    Any ideas???
  2. moosetags
    I trouble shot the problem on the '04 today and found the problem. the water tube to the rear window had become disconnected at a tubing joint next to the under hood fuse box right behind the battery. I reconnected the tube and the rear window washer is working again.
    The '05 had the same problem which was also easily fixed.
