Subwoofer: Facing Down or Up?
Discussion in 'Audio, Video & Gadget Tech' started by The Heater, Mar 20, 2012.
  1. The Heater
    The Heater Rockstar 100 Posts
    Hello, all:
    Has anyone had experience with both up and down facing subwoofer installation in an extended cab truck? Or just one of those positions?
    I have to decide if I will mount one or two sub woofers facing up or down. I have a current sealed box facing forward. Sounds great. 8 inch sub. But I want a larger unit, so it has to go up or down. The interior is all out of the rig, so now is the time to design something for a larger sub woofer or two.
    Any personal experience on these options as far as sound, vibration, etc. would be appreciated. :tuxout:
    Thanks,
    Mike
  2. Enkeiavalanche
    Faceing down you might have a deeper sound almost like a Bandpass. So your 8 could sound like a 10. It's a smaller space for the air to move and fill up..
  3. lquattro04
    lquattro04 Rockstar
    The closer a wall, floor, seat, etc. are to the face of the subwoofer, the louder it will be. This is due to the fact that the sound waves bounce off of the wall, or whatever it may be, and go throughout the cab in more than one direction. Right now I have a 12" Kicker L7 facing up in my crew cab, and unfortunately I was unaware of this fact before I had the custom box made. I had the sub previously in an S-10 extended cab facing towards the front right behind the drivers seat. From what I recall, the S-10 was nearly twice as loud as it is now. Now mind you the cab was smaller, but the sub would pound right behind my seat compared to my sub now which just goes towards open space.
    Hope this helps!
  4. SurrealOne
    Definitely down.
  5. mfleetwood
    x3 on facing down.
  6. zigger215
    In the 99-2007 trucks, up firing boxes will allow you to fit bigger subs (deeper), down firing has always seemed to sound better to me.
  7. reggiecab2000
    down fire for sure!
  8. Cheez
    Cheez Rockstar 100 Posts
    I've had both up and down in my 2004 extended cab. I prefer the down firing much more than the up firing. The only rattle problems I've had with the down fire is the spare tire tools. Rearranged them a bit and that problem went away. If you want to go bigger, a 12" downfire is about all you'll fit. 10" is a nicer fit but my 12" still hides itself under the seat nicely.
  9. The Heater
    Since you have to have a lip on the side where the woofer is mounted to allow for cone excursion, when pointing it down are you leaving one or two sides with no lip to allow air to move?
  10. Cheez
    When I built my box I left both sides open. It's pushed up against the back cab so it may as well just have only one side open.
